Now the Instruction Register (IR) block is implemented. This register transfer the nibbles separately. The 4-bit LSB nibble is transfered on the BUS, and 4-bit MSB nibble on the Control Block further up. This is a differential feature in relation to another registers that can transfer an entire byte on the BUS.
Fábio Gil
