All 3D parts
![](https://cdn.hackaday.io/images/4530431513332327212.jpg)
Filament Colorfabb nGEN gray
Filament Colorfabb FLEX black
Servo motor Modelcraft VSD-15E
8 x m3 nuts
2 x 16mm bolt (DIN 912 m3 x 16 12.9)
2 x 40mm bolt (DIN 912 m3 x 40 RVS)
2 x 45mm bolt (DIN 912 m3 x 45 RVS)
2 x 50mm bolt (DIN 912 m3 x 50 RVS)
10x 9,5mm screws (DIN 7983 2,2x9,5 RVS)
Building it togetter,
![](https://cdn.hackaday.io/images/2778521513332567325.jpg)
Added mini servo
![](https://cdn.hackaday.io/images/5471621513332854045.jpg)
Place gears, you have to cut the original servo star plastic to fit into the gear.
![](https://cdn.hackaday.io/images/4266011513332963337.jpg)
Take some tape to hold the nuts on place!
![](https://cdn.hackaday.io/images/1977151513333014862.jpg)
All parts togetter to bring into the bottom part.
![](https://cdn.hackaday.io/images/3959171513333059933.jpg)
Parts placed into bottom holder. (check servo wire)
![](https://cdn.hackaday.io/images/9637971513333134444.jpg)
Add flexible vilt at the grip left and right
![](https://cdn.hackaday.io/images/2293781513333208690.jpg)
drill holes and screw them onto the grip.
![](https://cdn.hackaday.io/images/4429111513333250974.jpg)
Grip with flex vilt
![](https://cdn.hackaday.io/images/603381513333294364.jpg)
Grip added to body
![](https://cdn.hackaday.io/images/7327141513333333373.jpg)
Both grips assembled on body.
![](https://cdn.hackaday.io/images/4819201513333381788.jpg)
Some pics of the result, ready to use.
![](https://cdn.hackaday.io/images/6082311513333427400.jpg)
![](https://cdn.hackaday.io/images/1002341513333455591.jpg)
![](https://cdn.hackaday.io/images/6615731513333476135.jpg)
