- Disable GPS reports when no sat's fix with u-blox software
- Add connection between INT on Teensy and PPS pin on GPS ( it will wakeup MCU from deepsleep on fix)
- Start to rewrite loop cycle code from RTC wakeup to Low Power Timer wakeup
- Write GPS code subsystem for manage GPS power including GPS fix failure after 60 sec.
- Add getting fresh GPS coords on refresh screen in VectorMap Application
