I love the Raspberry Pi, and while the it's for the best that they are, the HDMI, Audio and Power ports being on the side make them difficult to work with and integrate into a case. A lot of the time, projects can become a bit like spaghetti with cables coming out both sides which is something I absolutely want to avoid in the OverPi.
To solve this, I'm rerouting the HDMI and USB connector to the back of the case. Additionally, I will be redirecting the SD card there too.
For the HDMI, I purchased this interesting HDMI cable (I contacted them for a custom A-3 to A-Female cable). I'm excited to try it as it seems like an ideal, low-profile solution, way better than soldering a new connection or something.
For the USB connector, I purchased this Micro-USB breakout board. It will be very simple and cheap to connect to the Pi's GPIO 5v and ground ports. I am investigating adding some spike to this solution though, as it can be somewhat risky to power via the GPIO without it.
