Laser XY Scanner is an open source stepper motor based scanner. The components used are low cost and very accessible. This type of laser scanner is not extremely fast and has a fairly low resolution, especially with this driver, but it can still be used in a variety of applications. Draw, cut and or point with laser X and Y control.
There are many types but the traditional laser scanner is made with mirror galvanometers. These are very expensive and require even more expensive and complex controllers. You can think of them as high-speed servos. This XY Scanset in the photo above is currently $300+ and that does NOT include the controller.
This laser scanner is much simpler and slower but depending on your application it can still be very suitable. The simple 3D printed mount brings all these low-cost part together into something you can experiment with.
Happy laser-ing!
Josh Campbell
Hexastorm
smartDIYs
iliasam
FabLab München
It's really only fast enough for very small animations at a distance. That could be improved by using faster motors but at some point you realized you should probably just use a galvo if that is your goal.
I'm not sure why the images and other links are bad on here now. There is a link to a video on the github page with does work. https://github.com/ThingEngineer/Laser-XY-Scanner The camera doesn't capture the persistence but it is a solid square in person. Though that is about it's limit at desk to ceiling distance.
