So now we have everything to build a ternary computer in binary CPLD (or FPGA)::
https://cdn.hackaday.io/files/285791222723936/ternary.vhd
Last pieces were just added:
- procedure dmux:
PROCEDURE dmux(signal T_S: IN FakeTrit; signal T_C: IN FakeTrit; signal T_N: OUT FakeTrit; signal T_O: OUT FakeTrit; signal T_P: OUT FakeTrit) IS begin case T_S is when N => T_N <= T_C; T_O <= O; T_P <= O; when O => T_N <= O; T_O <= T_C; T_P <= O; when P => T_N <= O; T_O <= O; T_P <= T_C; when others => T_N <= X; T_O <= X; T_P <= X; end case; end;
- component ternary_mem:
-- Entity ternary_mem
USE ternary.ALL;
ENTITY ternary_mem IS
PORT (
T_S : IN FakeTrit;
T_N : IN FakeTrit;
T_P : IN FakeTrit;
T_Q : OUT FakeTrit
END ternary_mem;
ARCHITECTURE Behavioral OF ternary_mem IS
BEGIN
PROCESS (T_S)
BEGIN
IF (T_S(0) = '1') THEN
T_Q <= T_P;
ELSIF (T_S(1) = '1') THEN
T_Q <= T_N;
END IF;
END PROCESS;
END Behavioral;
- component ternary_clock:
-- Entity ternary_clock USE ternary.ALL; ENTITY ternary_clock IS PORT ( B_C : IN BIT; T_C : OUT FakeTrit ); END ternary_clock; ARCHITECTURE Behavioral OF ternary_clock IS signal flag : bit; BEGIN PROCESS (B_C) BEGIN IF (B_C'event AND B_C = '1') THEN IF (flag = '0') THEN flag <= '1'; ELSE flag <= '0'; END IF; END IF; IF (B_C = '1' AND flag = '0') THEN T_C(0) <= '1'; ELSE T_C(0) <= '0'; END IF; IF (B_C = '1' AND flag = '1') THEN T_C(1) <= '1'; ELSE T_C(1) <= '0'; END IF; END PROCESS; END Behavioral;
Last one turns binary clock into ternary sequence NOPONOPONOPO...
Also I renamed some variable names and added additional components for mux and dmux ( just in case if somebody doesn't like them as functions ; )
