Ternary memory latch
12/15/2017 at 10:14 • 0 commentsWIth two multiplexers (one trimux board) it is possible to build a memory cell:
Nixie tubes display for the ternary counter
12/15/2017 at 10:04 • 0 comments -
Program counter
12/15/2017 at 09:54 • 0 commentsOur computer needs a program counter. So we start with a schema:
Test it on a breadboard:
And here is the final program counter that will drive the TRIADOR:
Building blocks are ready
12/15/2017 at 09:48 • 2 commentsAs I said, the only building block allowed is a ternary multiplexer based on DG403 analog switches. With two DG403 it is possible to build a circuit bearing two ternary multiplexers:
Here is the layout:
The total budget for this project is set to 300 trimuxes or 600 ternary multiplexers. Here are all the components soldered, cleaned and tested:
