I moved into an apartment whose heating system is pretty old.
It has only valves that you rotate with knobs, and no pins that you push with a thermostat. Also the heating is common in the whole building, so I can't just replace them, I'd have to call a company.
So I took this opportunity to try and build my own system, learn a few things and have some good maker fun.
