new firmware v1.1.3 released
10/30/2018 at 05:49 • 0 commentsThanks for customer suggestions,and release new firmware v1.1.3
https://github.com/Resumer3d/info/tree/master/firmware_bin
1) move extruder away and disable all motors and heat, after filament run out ;
2) open fan after resuming. -
Support raspberry pi octoprint now
10/10/2018 at 02:17 • 0 commentsThe new firmware of resumer3d support raspberry pi octoprint, you can update it with boxtool.exe
change log:
1)fixed octopi print a lot of resend err;
2)heat bed first while resuming;
3)support no bed printer;
4)optimizte probe printer and reduce time;
5) old version of repetier-host can send gcode to set baudrate,e.g " M5000 250000" on MAC&windows;
How to make resumer 3D work with Filament detector?
09/22/2018 at 06:11 • 0 comments -
How to make resumer 3D work with Octoprint?
09/22/2018 at 06:10 • 0 comments -
How can I check the problem when Reusmer 3D does not work with my 3D printer?
09/06/2018 at 07:48 • 0 comments -
How to use Resumer 3D step by step after seting up?
09/06/2018 at 07:46 • 0 comments -
How to setup Resumer 3D with Mac computer?
09/06/2018 at 07:45 • 0 comments -
How to set up Reusmer 3D with Windows Computer?
09/06/2018 at 07:43 • 0 comments -
The mould of Resumer 3D has finished, and first batch will be 5000 Pcs!
06/26/2018 at 02:43 • 0 commentsResumer 3D really appreciate all your efforts, we have achieved 84% of our goals, and there are still 9 days to go, are you still waiting?
Reach it at kickstarter: https://kck.st/2xQmZYK
Good news is that we have finished the mould of Resumer 3D, as the following pictures show:
We will ship all your goods on July on time as promised. By the way, could you kindly share this project with your 3D printings friends? They may also need this product.
Thank you so much!
Best regards
Resumer 3D Team
