Print test
06/25/2018 at 14:33 • 0 comments -
Kickstarter online
06/05/2018 at 14:34 • 0 comments -
How to print a colorful hammer for Sol with resumer 3d by single extruder 3D printer?
06/05/2018 at 11:44 • 0 comments -
How to easily insert a part / airfoil into FDM 3d printed part with Resumer 3D?
06/05/2018 at 11:42 • 0 comments -
Resume a failure print(due to nozzle jam) from any printed layer automatically.
Resume a 3D print | WorldCup by Resumer 3D Due to Power outrage.
06/05/2018 at 11:40 • 0 comments -
05/21/2018 at 05:35 • 0 commentsLet`s try a worldCup! It works great!
How to print a colorful object with Resumer 3D by a single extruder printer ?
05/16/2018 at 08:06 • 0 comments -
Single extruder printer prints colorful objects with Resumer 3D.
05/06/2018 at 04:57 • 0 commentsWith Resumer 3D, you can interrupt the printings by yourself to change different colors of filament, after that resume the prints again with Resumer 3D.
We have tested this function, Resumer 3D can work perfectly, here are the pictures that show our testing results.
Test resumer 3D, resume the print (Resumer 3D cover) interrupted at the edge and middle.
05/04/2018 at 22:52 • 0 commentsAs you can see, we are printing the cover of Resumer 3D, we interrupted the print from the edge and the middle, then resume it again. It works perfectly when we interrupted it at the middle of the print; it works good when we interrupted it at the edge of the print, it may have a tinny circle line one the apperance, however it is still so good.
