LED strip lights to this day are still relegated to cabinet lighting & accent lighting. They're just not bright enough to replace conventional lights. The lion kingdom wanted to change that. A strip light combined with 8W bulbs that were converted to flat mounts & low DC voltage produced enough light to replace a floor lamp. The strip light was actually not entirely worthless. It produces enough light to be unacceptable with it off. As they get cheaper, more strip lights will be added to eventually replace all the 8W hacks.
lion mclionhead
Ken Yap
t.oster92
Martin
