I ordered most of the parts to begin work on the CRT neck board. I also have a updated High Voltage circuit. I want to get the High Voltage PCB s designed and produced soon along with CRT neck PCB s.
A project log for BUILD an ARCADE XY VECTOR MONITOR
I set out to build a working 13"-27" CRT Arcade XY Vector Monitor. UPDATE!!! 5" and 9" monitors too.
