There was an attempt to document more of the connections.
The 4 channel finally got the wifi power switch of the vlogging mic. Connect GPIO 18 to UART TX to put it in low power mode so the wifi doesn't interfere as much with single ended signals.
A project log for Ultimate 4 channel audio recorder
Portable, 2 channel, balanced input, 24 bit 96khz recording
