Updates in the version 3:
1. Power circuit update: previously a 3.7v battery is needed as the A9G power supply.
in the new version 3, the module can be powered either by battery , or directly by USB.
2. Battery voltage Monitor, to check the battery voltage
3. USB voltage monitor, to check if there a USB power connected;
4. 3.3V DC-DC module updated to 1A Version
5. SIM808 DTR connected to MCU, to make SIM808 enter sleep mode
Makerfabs
