WiFlyHQ Arduino library
An low memory use library for the Roving Networks WiFly.
The Roving Networks RN-XV WiFly module is an easy way to add WiFi network support to your Arduino projects. It has the same footprint as the XBee module and shares the same Serial I/O lines.
The WiFlyHQ library provides a high level interface to the WiFly module and has examples for an HTTP server, HTTP client, TCP server and client, UDP client, WebSocket client, and two router bandwidth monitors using SOAP and SNMP.
Rich text editor
DL wrote 05/26/2015 at 21:11 point
Any way to get the "set sys launch_string <string> function added for the version 4 firmware?
Ron wrote 07/01/2014 at 21:57 point
Wireless is the only way to go
