After spotting the guy on gootube who said it took only 3 hours to make a USB audio device out of an STM32F4, the decision was made to do it. The TOSLINK cable evolved out of a need to use the Yamaha intact & defeat power line noise, originally. The black & green boards were the parts from the Yamaha required just to go from TOSLINK to analog.
A custom USB board would be the most efficient way to expose an I2S output so the audio could be sniffed & go to 96khz. A big win is being able to plug it into a laptop or a raspberry pi.
Sniffing audio with any software solution wouldn't allow mixing it in a headphone monitor.
192khz seems rather pointless for its use.
lion mclionhead
