LED matrix boards are commonly available from places such as Adafruit and ebay. The official way of controlling them as part of a video wall involves a card based around an FPGA fed from a video signal.
This project aims to wring enough performance out of a microcontroller to drive at least one panel reasonably well. Currently a Teensy 3.1 has been used with reasonable success, though I'd like to move up to something faster and with more features.
No, I'm not entirely sure what the point of it is!
Despite appearances this project is not dead! I managed to assemble a complete board on about my fourth attempt!
This time I used a reflow oven and paste - I still had a few blobs to deal with but it was quite a bit easier!
Now I just have a lot of software to write and debug to get it working! It looks like the timing might be a bit off on the display driving code - some rows are brighter than others. I’m hoping this board might actually be powerful enough to use a timer rather than a loop which should make things more consistent.
After some poking around it was sort of working - not entirely surprising since the timing for driving these displays is quite tricky sometimes.
Unfortunately that questionable soldering did turn out to be a problem on some pins - while I think I’m getting the hang of soldering these things now, I’d bent some pins and while I did try to straighten them, it just made more mess and lifted a couple of tracks.
The good news though is that I have enough of a board to try out some other ideas on, and I should be able to assemble one more board properly now I’ve learnt what to avoid!
The STM32F407ZET6 parts come packaged telling you to use a vacuum pen to remove them and they’re fragile - they aren’t kidding about this! I got a cheap vacuum pen from Amazon and from playing around a bit it should make it far easier to not bend pins.
I’ll get there eventually!
The last rework attempt - while not entirely successful - did work fairly well until I spotted the bent pins.
after my previous failure to solder down the micro controller correctly, I bought a couple of slightly cheaper ones (I didn’t need all the power in the original anyway) and tried again. After some careful work it seems to turn on!
I can connect via an STLink v2 interface and openocd
I can toggle a pin on and off
I can connect via USB in DFU mode
I need to write more software to properly put it through its paces, but so far so good - despite the soldering looking a bit questionable in places!
As to where I went wrong last time, I think the answer is too much solder and not enough patience!
After sitting around for months I finally got around to attempting to solder up a board. It was going quite well until I made a complete mess of the qfp-144 stm32f417 which turned into a mess of solder blobs I couldn’t shift. I’m not sure if my iron wasn’t transferring heat properly or I just suck at it, but attempting to drag solder it just didn’t work out - maybe it was because I was using lead free solder but the blob stuck to the first pins and wouldn’t move down as I dragged the iron over it. Anyway I have some breakout boards for smaller parts of a similar pitch on the way and I will try again on those first before trying the led matrix board again
yeah - I have a flux pen and some desoldering braid. My first attempt used lead free solder and I don’t think my iron was really hot enough - one thing I realised the second time around is that I needed it way hotter than you’d expect so I’m starting to suspect it’s temperature gauge is a bit off which didn’t help.
Anyway I think I got there the second time - just need more practice heh
Lead free solder is awful stuff, I hate working with it...
