The LoFive houses a SiFive E310 RISC-V processor which has a lot of PWM channels, making it perfect for little robotics projects.
RISCbot also leverages a few Pololu breakout boards for the DRV8835 dual motor driver and S9V11F5 step-up/step-down voltage regulator to make the prototype a snap.
To start, RISCbot uses the E310's UART to receive data from a Spektrum DSM satellite receiver module, which is paired to a Spektrum transmitter.
The E310's SPI is broken out to a pin header on the board, as well as GPIOs for future expansion.
Check out the links section to find the project software and hardware design on GitHub.
Kurt Kiefer
