Recently, while doing some other work on the Z axis in the printer, I found that one of the PTFE leveling screw blocks had failed- it was getting wobbly. I decided to redesign the blocks for more stable mounting.
These blocks sit on the 4040 tee support frame and are held in place with an M4 screw and t-nut. They are very stable and the thickness of the blocks matches the length of the threaded portion of the leveling screws.
Here's how they look mounted on the tee:
Their positions can be adjusted as needed just by loosening the M4 mounting screw and sliding the block along the t-slot it sits in.
And a close-up showing one of the blocks installed:
Mark Rehorst
