"I have not failed 10,000 times. I have successfully found 10,000 ways that will not work."
-Thomas Edison
Honestly I knew many biosensors take decades of research, I didn't expect mine to be great, but stupidly I thought it might -- like a lightbulb--obviously just pass or fail and It did not, so far calibrations attempted and/or equipment have lots of error....
- Just beginning to realize the depths of uncertainty involved
- I need a controlled testing method because currently I am juggling too many variables
- I need to fix the calibration probably with more research and data collection (understand the relation to both BG and the Medtronic Guardian 3 data)
- I want to buy better thermistors and rebuild the ear piece
- Contemplating the significance of blood flow/ heart rate and if I should add a sensor for it
- (bad data seems to worsen or become more irradic around heart rate changes and higher BGs)
- Need more data
Between my own inexperience, inexpensive sensors, irregular blood sugars (lifestyle) I have not made much forward progress but I'm still slowly steadily trying.
Bethany
