Pioneer600
Pioneer600 sample program to control Raspberry pi with Joystick and monitor status on OLED of Pioneer600.
Video Sample : https://youtu.be/f1ea1XTvkac
Monitoring :
- Time / Date
- BMP180 infos - Temperature & Pressure & Altitude
- Raspberry Pi Info
- CPU Temperature
- RAM Usage
- CPU Usage
- Disk Usage
- IP Adresses
- Exchange Rates of TL (Turkish Lira & USD - EURO)
- KODI Command (Kodi must be installed)
- System Command
- Close this application
- Restart Raspberry Pi
- Shutdown system
- Startx
- Application Update (app-get update and upgrade)
- Raspberry Pi Kernel Upgrade rpi-update
- Close App
To add on startup Raspberry pi
sudo nano /etc/rc.local
and add this line, change directore if you install differant location.
sudo python /home/pi/Pioneer600/Pioneer600.py &
Module : Pioneer600 http://www.waveshare.com/wiki/Pioneer600
Raspberry Pi : B+ / 2B / 3B / Zero
Language Python 2
Used Pioneer600:
- LED sample
- PCF8574 sample - Joystick
- BMP180 sample programs- Barometer
- OLED sample programs
Details Installation:
Fistly installing packaged which needed.
sudo apt-get install build-essential libi2c-dev i2c-tools python-dev libffi-dev
sudo pip install Image
And you have to enable spi, i2c, 1-Wire. There are two way, in terminal or application in desktop mode.
In terminal screen
sudo raspi-config
Under Advanced Option -> Enable SPI, I2C, 1-Wire
And restart….
to donwload codes from github
git clone https://github.com/tayfunulu/Pioneer600.git
cd Pioneer600
To try
sudo python Pioneer600.py
to install kodi :
Sudo apt-get install kodi
