More volume control tweaks
A project log for GPS Talking Clock
Accurate time without a display
nick-sayerNick Sayer 01/25/2019 at 05:190 Comments
The latest design moves the volume control to after the preamp, which cuts down on the low-volume noise. I also changed the balance control to a through-hole trimmer so it'll be easier to adjust. I also found a .1" SIP trimmer that can be used for a board-mount volume control, or replaced with wires to a panel mounted volume control.
Rich text editor
