ZX81 BASIC, based on Shoulders of Giants improved code, hacked for operation at 7.375 MHz.
Contains two versions, one with normal 32-column text, another with experimental 40-column text.
This is a 32K ROM, use lower or upper 16K in the bottom 16K of the ZX80 memory map.
Both versions include a 2K monitor at 3800 hex.
0000 8K ZX BASIC 2000 2K blank (FF) 2800 2K G007 graphics 3000 2K blank (FF) 3800 2K ZX81 monitor 4000 As first 16K, but with alternative display width.
Connect the ROM A14 to a 1P2T switch, to select display width at reset.
The G007 graphics does not work without the G007 hardware. I just put it there for later experiments.
