ws2812 is an RGB LED which has individually included LED controller.
Each LEDs can be controlled one by one using serial signal.
I made a signal using an OC module and DMA and output an Audio port to the LED strip.
#include <sys.h>
#include <file.h>
#include <p270256b.h>
#define LEDs 60
#define OVERSAMPLEx 4
#define VLEDs (LEDs*OVERSAMPLEx)
typedef struct{
unsigned char r;
unsigned char g;
unsigned char b;
} led_t;
// ======led task======
// ===DMA setting===
// *addr ==> OC4RS
// trig TMR4 irq
// 1byte per event
// destination size is 1byte.
// src size is `size`
// DMA channel 1 and 2 for SD, channel 3 for keyboard, so we use channel 0 to audio.(No more DMA channel;)
void initdma(char *addr,unsigned size){
DMACON[SET] = 0x8000;
DCH0CON[ORIG] = 0x02;
DCH0ECON[ORIG] = (14<<8)|(1<<4);
DCH0SSA[ORIG] = ((unsigned)addr) & 0x1FFFFFFF;
DCH0DSA[ORIG] = ((unsigned)OC4RS) & 0x1FFFFFFF;
DCH0SSIZ[ORIG] = size;
DCH0DSIZ[ORIG] = 1;
DCH0CSIZ[ORIG] = 1;
DCH0INT[CLR] = 0x00FF00FF;
// DCH0CON[SET] = 0x80;
#define CLRFLG DCH0INT[CLR] = 0x00FF00FF
#define ISHALFDONE DCH0INT[ORIG] & 0x40
#define ISALLDONE DCH0INT[ORIG] & 0x80
// ===PWM settings===
// use timer3
// use OC4
// pwm max duty = 0xFF (8bit)
// output PB13
void setuppwm(void){
RPB13R[ORIG]= 5;
PR3[ORIG] = 60;
TMR3[ORIG] = 0;
T3CON[SET] = 0x8000;
OC4CON[ORIG]= 0x000e;
OC4CON[SET] = 0x8000;
unsigned char ledtransbuff[LEDs*24+60];
void initled(void){
setuppwm();
initdma(ledtransbuff,sizeof(ledtransbuff));
void calcdata(led_t *leds){
int i,j;
int t;
for(i=0;i<LEDs;i++){
t = 0;
for(j=0;j<OVERSAMPLEx;j++)
t += leds[i*OVERSAMPLEx+j].g;
t /= OVERSAMPLEx;
for(j=0;j<8;j++){
ledtransbuff
[i*24+j]=(t&(1<<(7-j)))?40:15;
t=0;
t += leds[i*OVERSAMPLEx+j].r;
t /= OVERSAMPLEx;
for(j=0;j<8;j++){
ledtransbuff
[i*24+j+8]=(t&(1<<(7-j)))?40:15;
t=0;
t += leds[i*OVERSAMPLEx+j].b;
t /= OVERSAMPLEx;
for(j=0;j<8;j++){
ledtransbuff
[i*24+j+16]=(t&(1<<(7-j)))?40:15;
void resend(led_t *leds){
calcdata(leds);
while(!(ISALLDONE));
CLRFLG;
void send(led_t *leds){
calcdata(leds);
CLRFLG;
void pattern1(int p,int l,led_t c,led_t *led){
int k;
l*=OVERSAMPLEx;
c.r /= l;
c.g /= l;
c.b /= l;
for(k=0;k<l;k++){
led[(p+VLEDs+k)%VLEDs].r += k*c.r;
led[(p+VLEDs+k)%VLEDs].g += k*c.g;
led[(p+VLEDs+k)%VLEDs].b += k*c.b;
led[(p+VLEDs+l+k)%VLEDs].r+=(l-k)*c.r;
led[(p+VLEDs+l+k)%VLEDs].g+=(l-k)*c.g;
led[(p+VLEDs+l+k)%VLEDs].b+=(l-k)*c.b;
int main(int argc,char **argv){
int i,k;
led_t led[LEDs*OVERSAMPLEx]={{0,0,0}};
initled();
send(led);
while(ps2keystatus[0xD]);
led_t col[]={{100,100,100},{200,100,0},{0,200,100}};
for(i=0;i<VLEDs/3;i++){
led[i].r = 150;
led[i].b = 150;
led[i].g = 150;
resend(led);
wait60thsec(30*8);
led[i].r = 0;
led[i].b = 0;
led[i].g = 0;
resend(led);
return 0;
while(1){
for(k=0;k<VLEDs;k++){
for(i=0;i<VLEDs;i++){
led[i].r = 0;
led[i].b = 0;
led[i].g = 0;
for(i=0;i<sizeof(col)/sizeof(col[0]);i++){
pattern1(k+i*90,4,col[i],led);
resend(led);
if(ps2keystatus[0xD])break;
resend(led);
// Return to quit.
wait60thsec(1);
return 0;
Gombe
