- The IR controlled outlet can also be customized by adding more relays
- The command codes for each relay can also be customized through the following lines of code
- The additional relays can be added to the circuit for the IR controlled circuit
A project log for Universal Remote Control
This remote controller uses the gen4-uLCD-35DCT (125-8025) as the main interface for sending IR commands.
