Production shall start soon with a small batch of 100 boards which will be available on an online shop.
Final board will be smalled with an external NFC antenna with an U.FL cable to connect HydraNFC with HydraNFC Antenna.
A project log for HydraNFC Shield v1
HydraNFC Shield v1.0 is an NFC hw shield to sniff/read/write/emulate any 13.56MHz NFC tags for advanced NFC Research/Dev/Debug/Hack/PenTest
