# Voipac VPACLink
# http://voipac.com/27M-JTG-000
telnet_port 4444
gdb_port 3333
#interface ft2232
#ft2232_device_desc "VPACLink"
#ft2232_layout oocdlink
#ft2232_vid_pid 0x0403 0x6010
#adapter_khz 100
interface ftdi
ftdi_device_desc "Dual RS232-HS"
ftdi_vid_pid 0x0403 0x6010
ftdi_layout_init 0x0c08 0x0f1b
ftdi_layout_signal nTRST -data 0x0100 -noe 0x0400
ftdi_layout_signal nSRST -data 0x0200 -noe 0x0800
adapter_khz 1000
#reset_config none
# Freescale i.MX51
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME imx51
# CoreSight Debug Access Port
if { [info exists DAP_TAPID ] } {
set _DAP_TAPID $DAP_TAPID
} else {
set _DAP_TAPID 0x1ba00477
jtag newtap $_CHIPNAME DAP -irlen 4 -ircapture 0x1 -irmask 0xf \
-expected-id $_DAP_TAPID
# SDMA / no IDCODE
jtag newtap $_CHIPNAME SDMA -irlen 4 -ircapture 0x0 -irmask 0xf
# SJC
if { [info exists SJC_TAPID ] } {
set _SJC_TAPID SJC_TAPID
} else {
set _SJC_TAPID 0x0190c01d
jtag newtap $_CHIPNAME SJC -irlen 5 -ircapture 0x1 -irmask 0x1f \
-expected-id $_SJC_TAPID -ignore-version
# GDB target: Cortex-A, using DAP
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME cortex_a -chain-position $_CHIPNAME.DAP -dbgbase 0x60008000
# some TCK tycles are required to activate the DEBUG power domain
jtag configure $_CHIPNAME.SJC -event post-reset "runtest 100"
# have the DAP "always" be active
jtag configure $_CHIPNAME.SJC -event setup "jtag tapenable $_CHIPNAME.DAP"
nand device 29F4G08ABADA mx5 $_TARGETNAME hwecc biswap
init
proc imx51_dbginit {target} {
# General Cortex A debug initialisation
cortex_a dbginit
proc load_uboot {} {
halt
arm core_state arm
load_image /home/theosoft/imx-build/u-boot/u-boot.bin 0x97800000
# sdhc 0 0x97800000 0x400 0x4d000
step 0x97800000
proc n_steps {steps} {
for {set a 0} {$a <= $steps} {incr a 1} {
step
# Debug Status and Control register
proc dscr {} {
echo [format 0x%08x [arm mrc 14 0 0 1 0]]
# MMU disable
proc mmud {} {
reg cpsr 0x1d3
echo [format 0x%08x [arm mrc 15 0 1 0 0]]
arm mcr 15 0 1 0 0 [expr {[arm mrc 15 0 1 0 0] & 0xffffcc7a}]
step
proc wdt_disable {} {
# disable WDT
mwh 0x73f98000 0x3
# This program resets the regs to the address 0x17800000
# making the incorrect assumption that the start of the code
# is located there.
# It sets up the cpsr so we can run the code properly.
proc clear_regs {} {
puts "clear_regs begin"
reg r1 0
reg r2 0
reg r3 0
reg r4 0
reg r5 0
reg r6 0
reg r7 0
reg r8 0
reg r9 0
reg r10 0
reg r11 0
reg r12 0
# assume our executable is at 0x17800000. otherwise the
# user must manually set the value after a reset.
reg pc 0x97801000
# shamelessly stolen from the samsung configuration
# this fixes problems executing loaded code.
reg cpsr 0x1d3
arm mcr 15 0 15 2 4 0x70000013
puts "clear_regs end"
# MMU enable
proc mmue {} {
reg cpsr 0x1d3
arm mcr 15 0 1 0 0 [expr {[arm mrc 15 0 1 0 0] | 0x00000005}]
step
# prepare memory access for registers AXI and IP
proc pm {} {
halt
mmud
dap apsel 1
# erase page 0 to enable bootstrap
proc bt_enable {} {
pm
#set high Address
mww 0xcfff1e04 0x0
mww 0xcfff1e24 0x0
#set ram to block 0 and NFC reset
mww 0xcfff1e34 0x0
#set autocmd autoprogram
mww 0xcfff1e00 0x0070D060
# do auto_erase
mww 0xcfff1e40 0x20
sleep 500
mdw 0xcfff1e3c
# program flash with autowrite NFC option
# number in Range 0x00000000 - 0x000007ff --> Page 0
# number in Range 0x00010000 - 0x000107ff --> Page 1
proc pfpart {p_start p_stop} {
# todo
# NAND's CMD setzen 0x80 0x10
# RAM füllen
# Addr0 und Addr8 setzen
# Auto erase ??
# RAM Quelle setzen
# Autowrite setzen
# register read and set bits ??
# set p_start 0x00030000
# set p_stop 0x000030800
set start_len [string length $p_start]
set stop_len [string length $p_stop]
if [expr $start_len != 12] {break}
if [expr $stop_len != 12] {break}
scan $p_start %x start_int
scan $p_stop %x stop_int
if [expr $stop_int < $start_int] {break}
#convert real address to flash address
set block_len [expr $stop_int - $start_int]
set start_flash_int [expr $start_int << 1]
set stop_flash_int [expr $stop_int << 1]
set addr0_start_shift_h [expr (($start_int & 0x00fffff800) << 5)]
set addr0_stop_shift_h [expr (($stop_int & 0x00fffff800) << 5)]
set addr0_start_shift_l [expr ($start_int & 0x00000007ff) ]
set addr0_stop_shift_l [expr ($stop_int & 0x00000007ff)]
set addr0_start [expr (($addr0_start_shift_h | $addr0_start_shift_l ) & 0x00ffff07ff)]
set addr0_stop [expr (($addr0_stop_shift_h | $addr0_stop_shift_l) & 0x00ffff07ff)]
set addr8_start [expr (($start_flash_int & 0xff00000000) >> 32)]
set addr8_stop [expr (($stop_flash_int & 0xff00000000) >> 32)]
#block overlap not supported till now
if [expr $addr8_start != $addr8_stop] {break}
echo [format "0x%.8X" $addr0_start]
echo [format "0x%.8X" $addr0_stop]
echo [format "0x%.8X" $addr8_start]
echo [format "0x%.8X" $addr8_stop]
echo [format "0x%.8X" $block_len]
pm
#set high Address
# mww 0xcfff1e04 $addr0_start
# mww 0xcfff1e24 $addr8_start
#Helps, but don't now why
reg pc 0
# mww 0xcfff1e34 0x0
# mww 0xcfff1e00 0x00001080
load_image one_page.hex 0xcfff0000 0x800
#write autoprog cmd
# mww 0xcfff1e40 0x40
# dump flash with autoread NFC option
proc dfpart {start stop} {
# set start 0x1ff70000
# set stop 0x1ff80000
set start_len [string length $start]
set stop_len [string length $stop]
if [expr $start_len != 10] {break}
if [expr $stop_len != 10] {break}
scan $start %x start_int
scan $stop %x stop_int
set start_flash_int [expr $start_int << 5]
set stop_flash_int [expr $stop_int << 5]
set addr0_start [expr ($start_flash_int & 0x00FFFF0000)]
set addr0_stop [expr ($stop_flash_int & 0x00ffff0000)]
echo [format "0x%.12X" $addr0_start]
echo [format "0x%.12X" $addr8_start]
echo [format "0x%.12X" $addr0_stop]
echo [format "0x%.12X" $addr8_stop]
echo [format "0x%.12X" $block_len]
#prepare memory
pm
#set high Address
# set b $start_int
for {set a $addr0_start} {$a <= $addr0_stop} {incr a 0x10000} {
reg pc 0
mww 0xcfff1e34 0x4
#set adress to page begin
mww 0xcfff1e04 $a
#autoread
mww 0xcfff1e40 0x80
# sleep 500
set fn1 [format "0x%.8X" $start_int]
set fn2 [format "_0x%.8X" [expr $start_int + 0x7ff]]
dump_image dump$fn1$fn2.hex 0xcfff0000 0x800
echo $fn1$fn2
set start_int [expr $start_int + 0x800]
echo "Finished partial flash dump"
# dump flash with autoread NFC option very slow !!
proc dffull {} {
set flash_Start_Addr 0x00000000
set flash_End_Addr 0x07ffffff
dfpart {$flash_Start_Addr $flash_End_Addr}
set flash_Start_Addr 0x08000000
set flash_End_Addr 0x0fffffff
set flash_Start_Addr 0x10000000
set flash_End_Addr 0x17ffffff
set flash_Start_Addr 0x18000000
set flash_End_Addr 0x1fffffff
proc dasm {addr {length 8}} {
arm disassemble $addr $length
proc reset_halt {} {
adapter_khz 100
halt
bp 0 4 hw
resume
jtag_reset 0 1
sleep 500
jtag_reset 0 0
# Slow speed to be sure it will work
$_TARGETNAME configure -event reset-start { adapter_khz 100 }
$_TARGETNAME configure -event reset-end { jtag_rclk 1000 }
$_TARGETNAME configure -event reset-assert-post "imx51_dbginit $_TARGETNAME"
proc init_l2cc {} {
# enable L1NEON bit
arm mcr 15 0 1 0 1 [expr {[arm mrc 15 0 1 0 1] | 0x20}]
# explicitly disable L2 cache
arm mcr 15 0 1 0 1 [expr {[arm mrc 15 0 1 0 1] & ~0x2}]
# reconfigure L2 cache aux control reg
arm mcr 15 1 9 0 2 0x01C000C4
#proc boot {{FILE barebox.bin}} {
# halt
# arm core_state arm
# load_image $FILE 0x90000000
# step 0x90008000
# resume
#proc vmx51_init {} {
# echo "Configuring VMX51..."
# halt
# # set ARM state
# # set SU mode, disable MMU
# arm mcr 15 0 1 0 0 0x00050078
# reg cpsr 0x1d3
# adapter_khz 1000
# init_l2cc
# init_aips
# # disable WDT
# mwh 0x73f98000 0x30
# # init DDR2
# init_ddr2
# echo "Initialisation completed..."
JTAG & Serial definitions:
Soldering looks bad, but i had to try a lot of combinations :)
For orientation: the left blue is pin 1 and the lower row ends with 10
The upper row starts with 11 and ends with 19. Pin 11 is above pin 2.
T-Hub Pin | Description | 20Pin ARM Jtag |
1 | Gnd | 2,4,6,8,10,12,14,16,18,20 |
2 | Vref 1.8 Volt ! | 1 |
3 | nreset ?? | 15 may be not needed |
4 | TDO | 13 |
5 | TDI | 5 |
6 | TCK | 9 |
7 | RTCK ?? | 11 may be not needed |
8 | TMS | 7 |
9 | nc | |
10 | nc | |
11 | nc | |
12 | Gnd | |
13 | RxD 3.3 Volt | |
14 | TxD 3.3 Volt | |
15 | nc | |
16 | nc | |
17 | nc | |
18 | nc | |
19 | nc |
