Tiny, isolated USB to Radio Interface
Modular USB Hub, Serial interface and sound card for your old(ish) radio station without USB
The interface is based on a USB hub with three USB ports. On the PC side, the interface is connected only with one USB cable, which serves for data transfer and provides power. The whole interface fits inside the standard casted aluminum housing with outline dimensions of only 100x50x25mm.The interface is modular and provides several different configurations according to specific needs. There are three ports on the USB HUB. The ports 1 and 2 are always available for additional modules, and on the port 3 is shared either the CAT / PTT / CW interface that is already installed on the hub itself or the auxilary USB connector for additional external devices. The sound and CAT module can be connected to USB HUB ports to expand the functionality of the interface.
Block diagram of the interface
JPEG Image - 58.57 kB - 01/05/2018 at 07:20
Preview
Bharbour wrote 10/20/2019 at 13:09 • point
Nice job!
fabian wrote 04/24/2018 at 20:21 • point
is posible to add this to https://disaster.radio/ for example baofeng+esp to communication
