WatchMeter is a low power wrist multimeter. Very portable and intended for quick measurements and unexpected situations.
WatchMeter_V1_PCBProject.zipZip Archive - 6.20 MB - 01/07/2018 at 18:24 |
WatchMeter_Schematic.PDFAdobe Portable Document Format - 452.99 kB - 01/05/2018 at 16:35 |
Just found-out about a really bad design of the SAML21 micro. In order to use it's DAC as an internal reference for the internal OpAmps I must output the DAC to it's IO pin (pin 3, in the case of DAC0). The problem is that pin 3 is shared with OpAmp0 negative input. It is then impossible to use the DAC0 AND the negative input of OpAmp0 at the same time...
So I won't be able to implement the following current source circuit with this micro.
For version 2 I will probably change the microcontroller...
- Boards just arrived from OSH Park. Still waiting the components to arrive...
Proof of concept...
Proof of concept - Hardware
Hi! Indeed it could be fixed with an external voltage reference, but I was planning on saving space using the chip's DAC.
This project was supposed to be an entry to the Coin Cell Challenge and because I didn't have much time I choose this micro without looking deeper on its specs and used a 4-layer PCB to speed-up the layout.
For future versions I plan on using the MSP430I20XX. One could also change the CR2032 holder to save more space and have 2-layer board, but for now the project is stopped..
Anyway, thank you for the interest in this project :)
For your log on "Bad ATSAML21 design", in order to avoid the conflict of DAC output for current source, wouldn't it be good to use an external ref for Opamp0?
I have an additional question. In order to simplify it to a 2 layer PCB and using Current-to-Voltage (TIA) opamp config, do you think this mictocontroller is a good idea?
Thanks in advance.
