Since March I have been working on a dedicated board to contain the whole system. Here is the link to the OSH park board
https://oshpark.com/shared_projects/JiEvGsBk
Caution - the output stage produces 80 volt peak to peak which is dangerous, but also within specs for the sonar transducer.
Improvements
- This board has improved power supply decoupling and less ripple.
- It has an input for 5v power to supply the current for the 40volt internal step up supply.
- Microphone holes in the board are better and solder pattern better match specs
- Microphone holes are 2.7mm apart
- High accuracy clock
- Complete self-contained board.
Issues
- Minor amount of noise on the transducer output - sounds like noise from the MCU. Likely routing issue- capacitive coupled analog input close to digital output. Does not seem to affect performance.
Filip Mulier
