Serial Isolation working
A project log for Bench power supply
USB and manual control, and monitoring, 2 channel 5A 30V bench supply.
rue-mohrRue Mohr • 07/25/2014 at 14:15•0 Comments
The 6n137 worked great for isolating the serial at a ttl level, full baud rate isn't a problem.
Cant say the same thing about hackaday.io when used with iceweasel.
I will made a point of posting the isolator schematic  (its pretty straight forward if you get your pullup resistors the right way around)
I really have to make the new buck converter now, I keep putting it off... I got the P channel fets and they are great. One of them is running a solar project at the moment.
I hearby click publish trusting my text will not dissapear...
