Sensor Module Revision One
A project log for HydroPWNics
An open source hydroponic garden control, monitoring, and grow system with cloud database and dashboard.
avrAVR 04/27/2015 at 03:020 Comments
Posting back twice in the same day ha!!!! Laughing aside I finished the Sensor Module from earlier, the source files can be found here along with a PDF of the schematic:
https://github.com/adamjvr/HydroPWNicsHardware
Overall the design didn't take that long, I have working circuits for both the DCDC and FreeScale so all I had to do was copy the schematic and the board took not much longer. In order to keep the costs down I made the PCB as small as possible and kept it to 2 layers. Soon I will order the board from OSHPark and write the firmware using the Motate hardware abstraction system found here: https://github.com/giseburt/Motate Motate is essentially a embedded hardware abtraction library written in C++ sort of like Arduino but with a focus on performance instead, I've played with it before and the FreeScale chip I used is supported by it.
Picture of the Board
3D Render of the Board
Rich text editor
