Non Pneumatic Tire / Airless Tire (actually just the wheel), matching tire and hub attachment (for printing the wheel without supports)
BasWheel v 2.00: Added tire_compatibility "rc1_10", added parameter rim_dxf, changed parameter names from dxf_filename to spoke_dxf and from spring_segments to spoke_segments, added spoke_type "Polaris_TerrainArmor"
BasWheel v 2.01: Added spoke_type "Hankook_NPT"
BasWheel v 2.02: Added spoke_type "segmented" and parameter spoke_angle. Fixed a bug with rim_type "barrel"
BasWheel v1.28: Added parameter rim_type
Added a hole on the outer wheel to match the hole on the hub_type "screw"
BasWheel v1.27: Added parameters hex_screw_spacer, hex_screw_OD, hex_screw_ID, hex_screwhole_depth, hub_magnet_count, hub_magnet_margin, hub_magnet_diameter and hub_magnet_height
BasWheel v1.26: Added hub_type "hex" and parameter hex_size
BasWheel v 1.25, 14 Mar 2014 : Added spoke_type "dxf" and parameter dxf_filename.
Soon to follow a how-to tutorial for the spokes dxf generation.
BasWheel v1.24: added parameters tire_compatibility (either custom or pololu90 compatible tire) and flip_wheel (0: not flipped, 1: flipped)
