Hackaday.io Hackaday.io
Sign up Log in
2D Laser Range Finder under $80
A 2D Laser Range Finder with 100 degree field of view for under $80 with no moving parts
rlsutton1rlsutton1
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
29 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
649
0
29
2
Team (1)
  • rlsutton1rlsutton1
Join this project's team
completed project
This project was created on 09/07/2014 and last updated 11 years ago.
Description
I've seen other Laser Range Finders using a dot laser and a web cam, and decided I could use a line laser and multiple web cams to produce a field of laser ranges.
2 Logitech c270 web cams provide a 100 degree field of view, and a common 5mw line laser with a 120 degree lens provides a line across the entire field of view.
I've designed a mount to off set each web cam 25 degrees respectively left and right, also tilting them up 11 degrees to make their vertical field of view from horizontal to ~+22 degrees. The laser is mounted 110mm above the base and this gives the range finder a theoretical range from ~20cm to infinity.
I've written a custom image processing algorithm in java leveraging opencv via javacv
see the video in the project logs
Project Logs
Collapse
  • Video of a basic test
    rlsutton1 • 09/09/2014 at 20:34 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
3D printed holder for two line and one point laser allowing targeting and focusing of laser cutter head.
Project Owner Contributor
Targeting Laser for Laser Cutter
florian-festiFlorian Festi
Using a DVD burner laser as a projection microscope
Laser Projection Microscope
jJ
Draw patterns on the surface of a table using glow-in-the-dark paint and a laser pointer.
Laser Table
ben-wienerBen Wiener
Steampunk polycarbonate laser safety glasses for CO2, UV, and Fiber lasers.
SteamPunk Laser Safety Glasses
builder4brickbuilder4brick
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "2D Laser Range Finder under $80", please tell us the reason.
Send message
Remove Member
