I've gone through and restructured the code to be more efficient and cleaner. This was mainly to support bruteforcing the ciphers.
The brute forcing page is currently separate from the main page and can be found at http://otp.portablesofdoom.org/brute.html
I have only tested it with a few messages, but it works. It takes a little bit of time to respond though, so be warned.
gannon
