The output board is near completion. It still very long to do such things when not all parts are in the house and I need to wait for them. It take ages. Add to it the fact that when in August everything is slow in this country.
No very proud of the 5V regular near the jack socket, nor the header pins for power right beneath the pot.
Once this board is good, the synth will be finished and will be put in its case.
I'm working on the front panel.
The power supply will be external and housed in a ABS case.
