ESP32 powered Home Automation System
A smart ESP32 powered Home Automation System. It could be embedded in switchboards of your house.
I designed this home automation system to fit inside a regular 8 channel switch board. Each channel in capable of AC dimming at 240V. Along with this each channel can handle 8 Amperes of current.
The board is based on ESP32 and gives the board WiFi connectivity to be able to control each channel via WiFi. I also developed an Alexa skill to control the modules using Alexa. Later on it can also be integrated with google assistant.
K.C. Lee wrote 11/23/2018 at 10:23 • point
WiFi in a metal box?  Hope you plan for external antenna or left the front open.
Akshay Baweja wrote 11/23/2018 at 10:26 • point
Hey,
This metal box goes inside your wall and upper surface is covered with plastic switches so there is no hindrance to the WiFi Signal
