This is very use full for when you are camping or when you want to read anything in dark lighting situation like a story book or map.
View all 6 components
Make sure every parts are ready!
cut the acrylic sheet correct size
fix smd led's using glue and solder the wires. I solder 2 led's in parallel and each pair in series.
View all 5 instructions
scubabear
Tinic Uro
awkward intelligence
Sina Roughani
Yes, delete it Cancel
You are about to report the project "LED Reading Pad", please tell us the reason.
