The fun part for me was putting it all in a wooden box, and trying out panel-mount components for the first time. There's a power-switch where the LED lights up when a power source is connected, so I don't leave a LiPo in it. There's a play/stop button, and a barrel jack on the back for wall power. I even used the normal pin on the jack to disconnect the battery connector when a wall source is connected, so I can't accidentally blow up a LiPo.
I also built a little servo distribution board out of veroboard. Unfortunately that was inspired by melting one of my servos after reversing power and ground -- building headers for the 3-pin connectors helped avoid that happening again.
Thanks to Andrew Hunt for the loan of the recording equipment (Canon XA25 and EV RE20), and to Zach Horsley for the inspiration.
Michael Murillo
Jay Riedl
bryan.lowder
Is it possible to also include the generated rpi files(e.g. sweetchild.rpi)?
