The grips are based on 3/4" aluminum square tubes. The predicted squeeze strength is around 40 pounds.
What about safety? Using PyUltimateRobot (see that Hackaday page), one can limit maximum force of any component of any movement. For example, you can program the robot to never use more than 1 pound of force unless explicitly commanded as needed for a particular movement.
