Found a bug in the design with the wrong resistor creating a current restriction. I also increased the capacitance a little too. In general, this should improve larger EL lengths.
A project log for MAX14521E EL Driver Flex Module
This is a Flex Module that drives 4 EL 'lamps' by i2c control. It supports audio modulation. For sale on Tindie.
