Finally this Saturday the Photobooth was used the first Time :)
The Footobooth from below the Fotoposition:
The Photobooth in use:
Finaly the Setup consists of the 7x5 LED Board, The Plywood/Acryl housing, the Aluminium profiles, 3 Daylight Lamps and the Canon EOS 400d.
Fazit:
On the plus side:
- The people really liked the concept of a Selphie Cam
- Some people said that its an amazing contraption
- Some people liked the Smiley
- If you also have "masking parts" for the people there will be amazing fotos
- From 711 there are about 450 usable fotos (~150 apertures @ 90 People)
- The Image size allowed generous cropping
On the minus side:
- Most images needed cropping
- There should be markings on the ground to make the pictures more "repeatable" (Often there were cut off feet)
- There was a bit less light especially after sunset (The exposure time went down to 1/15s, which is way to low)
- Some people used to fiddle around with the camera direction.
- The "review" of the Images was not convenient.
