Click here to view the complete source on github.
All I do here to convert from 8 bit to 1 bit samples is to decide a cut off point approximately midway in the value between 0 and 255 depending on how it sounds when I preview.
In this example, we check is this current sample greater than decimal 128 ?
If it is we say then that this bit is on and off otherwise.
This is stored in an array which is used later for playback and dumping for microcontroller compatible C.
for (i = 0; i < rawDataSize; ++i)
for (j = 0; j < BUFFER; j++)
if (rawData[offset] > 128)
buf[j] = 255;
else
buf[j] = 0;
int z;
for (z = 0; z < output_bitrate_divisor; z++)
offset++;
/* snip snip snip */
In order to offer a sample rate down conversion I used a naive approach of just skipping samples in the source array.
Once the samples have been converted to a 1-bit resolution it's now simply a case of going through those converted samples and joining them together to make a string of 8 bits; aka 1 byte of storage.
if (mode == P_STDOUT)
/* get 8 bytes from buffer */
for (j = 0; j < BUFFER; j = j + 8)
if (process_begun)
printf(", ");
else
process_begun = 1;
if (!(obsample_bytes % 15))
printf("\n");
/* move through those 8 bytes and convert to binary. 0x00 = 0, 0x255 = 1. */
unsigned char converted_bits;
converted_bits = 0;
for (k = 0; k < 8; k++)
if (k >= BUFFER)
/* trying to read past buffer? */
fprintf(stderr, "Critical error: Tried to exceed BUFFER.\n");
exit(1);
converted_bits = converted_bits << 1;
converted_bits = converted_bits + (buf[j + k] == 255);
obsample_bits++;
printf("%#04X", converted_bits);
obsample_bytes++;
