So... I started poking through the ROM for Megaman X (V1.1) and noticed some copy protection.
Some key points:
- Some of the copy protection routines check for SRAM and will aggressively screw with the game when it is detected.
- The original MMX cartridge PCB used a 74LS00 chip, which caused some data to be mirrored (show up in the memory map in a couple locations). The game checks to make sure the data is mirrored, but never actually uses the data from mirrored locations.
- The game checks to see if the copy protection routines are modified. There are also a couple more checks that attempt to detect if these same detection routines have been modified.
To avoid the protection routines, I simply JMP over each routine. More information and source code here.
DackR
Could you share an IPS file with the changes you made on the game to disable the copy protection? I do not know how to use the files that you shared on github
