Connect the WEMOS D1 Mini ESP8266 with Ubidots
A project log for Connect the WEMOS D1 Mini ESP8266 with Ubidots
Set up your WEMOS D1 mini with Ubidots in a few minutes using the Arduino IDE.
maria-carlina-hernandezMaria Carlina Hernandez 01/11/2018 at 15:330 Comments
The WEMOS D1 Mini ESP8266 is a development board similar to Arduino and developed especially for cost effective Internet of Things applications and solutions. Also compatible with Expressif's ESP32, the WEMOS series is perfect for educational and hobby IoT projects. With a 32 bit architecture (more powerful than the Arduino Due) and WiFi connectivity, you can choose between the Arduino and Lua languages for your application's development.
In this tutorial we will demonstrate how to setup and program the WEMOS D1 mini and an ESP8266 with the Arduino IDE to display your data with Ubidots.
