getting closer
A project log for PixelWand
a 3ft wand for lightpainting
russell-hayRussell Hay • 03/27/2014 at 20:49•0 Comments
After lots of trial an error, I think I have a design that works and will go together properly.  I only have a few of the parts cut right now because I keep running out of acrylic, but what I have is looking promising:
One thing I've discovered about the laser cutter is that the cuts are beveled, not perfectly vertical, so I absolutely have to glue them together even though i was hoping to get away with just press fitting them together.
Does anyone have that experience or is our laser cutter just out of whack?
