ok, so now pretty much all of it is done...
from left to right, we have:
the LED array
the rainbowduino V3 board
a lipo battery (the piezo will go here too)
a board which supports the switch
a board that holds the switch in place
some height adjustment bits with some springy sponge (switch spring is not strong enough on its own)
this fits into the box which contains the lipo charge/boost board, mode switch and power switch (some burn marks from a heat gun)
