Improving Sending Time
A project log for Ultimate Universal Remote
Improving a Griffin Beacon to add Bluetooth RF control, Command sequence sending and USB power
joedefajoedefa • 11/20/2014 at 18:34•0 Comments
The Delay needed for the RF module is very short but the code that I use is making the delay longer. Adding some compopnenants to smooth voltage when sending the signal seems to improve the delay and recovery time when the signal is received by the Attiny.
- Removed delay time in status LED blinking
- Need to add the use of interrupts in code if a signal is received while processing another signal to be executed later
