(On rev2 i flipped the connector so the wifi points away from the board.) but i like the compact design, and it doesn't seem to affect range.
One node streaming with mostly full data change per frame.
A project log for Cypress PSOC 4 + ESP8266 WS2812 RGB XMAS Lights
802.11 WIFI enabled RGB LED Strips, using the ESP8266 and $4 Psoc 4 dev board.
