I've updated the lua code to read the temperature from a 1-wire temp sensor using the code provided with the nodemcu firmware
Results are on the same thingspeak channel https://thingspeak.com/channels/17374
I'm quite impressed with the nodemcu firmware. It makes it very easy to write simple scripts like this. Still don't like the upload method though!
Matt Callow
